OK, some quick clarification.
Q-jets are either 750 or 795 (800, whatever) CFM. 800's are much more common later on, 305 trucks got 800's exclusively from what I've seen, while the Monte SS's with 305's didn't, go figure. Oldsmobiles with 307's typically got 800's as well. The CFM difference is on the primary side, my *speculation* is that they were going for more torque down low, which is why you see many more 800's later on with the smaller engines. You do not see very many 800's from the 70's, nowhere near what you do in the 80's.
Electrical plug that confirms it's a CCC (computer) Q-jet is on the drivers side of the carb, TPS. Passenger side plug on carb does NOT mean it is computer controlled, because that can be a dual capacity solenoid and/or one other piece of something I can't think of.
I agree though, I wouldn't mess with any of those, it's not something you NEED, and does complicate the rebuild kit, and probably drives up cost.
What year did the Pontiac 301 die? 1981? I'd make sure before purchase that it IS the chevy pattern, and not a CCC model or 301 as mentioned. Chev difference is mainly going to be the fuel inlet (believe Pontiac was like Olds, straight in, not from the side like Chev someone can correct me that knows Pontiacs) but also important is the choke. You need the choke style to match your intake. If mechanical, it has to, or you will end up trying to swap parts around, which is not always easy, OR go with the electric choke, which is very pricey to fix if it's bad.
I don't think I've ever even looked closely at the secondary throttle jets, that's a good tip. I've certainly seen secondary rods with rings worn in them.
