ROCKCRUSHER D60 Center section SALE !!!!!
Trent Fabrication
Registered Member
Reno/ Sparks/ Tahoe City
D60 center section $799.00 each
These center sections retail for $1068.93
Rockcrusher 60R Differential Housing
This is actually Rockcrusher's first innovative product for the off-road industry: the Rockcrusher 60R Differential Housing. The Rockcrusher 60R was/is designed for the serious 4-wheelers who demand the best in performance and value. Rockcrusher's 60R offers many engineered and integrated design features that were an innovative 'first' in the year 2000.
All other currently available Dana 60 high pinions have only a single oiling gallery. When they are used as a rear diff, pinion bearings can experience excessive wear and pre-mature failure due to insufficient lubrication. This is particularly problematic under extreme conditions, high pinion applications, and highway use. The Rockcrusher 60R is the only high pinion diff to feature 3 oiling galleries for enhanced pinion bearing lubrication and long life.
The Rockcrusher's Tri-Flow design features 3 oiling galleries for reduced pinion bearing wear: the most efficient pinion bearing lubrication system of any high pinion D60 available. This Tri-Flow design is owned by Rockcrusher and is patent pending.
Why You Want It…
• Cast from Heat Treated 100% Ductile Australian Steel
• 3 Integrated Mounting Plates with 8 Tapped Holes for Custom Suspension Links, Torque Bars, Pan Hard Bars, etc.
• Works with Standard High Pinion D60 Internals and Seals That Are Available at Any Auto Parts Store.
• No Ring Gear Modifications or Shaving Required
• Thickest Bearing Caps Available
What You Get…
• A Quality, Extremely Well-Built, Super Beefy Differential Housing
• A Heavy-Duty Cast Diff Cover Included at No Extra Charge
• Quality High-Grade Hardware and H-14 Hex Bit Fill Plug
• Diff Cover Includes Reinforced Ribbed Design that Helps Dissipate Heat & Provides Rigidity & Extra Protection.
• Diff Cover also Includes Recessed Bolt Seats for a Premium Surface Mounting Contact.
• Exclusive 'FLAT FIT' Fully CNC Machined Gasket Surface Seals Properly with No Leaks.
• A Far Superior Product over Other Competitive Models
• Improved Protection, Strength, and Durability
• Security for Your Time & Investment
• No Leaks or Drips in Your Driveway
• Delivers 35% More Clearance and 80% More Strength
• 20 lbs Lighter than Other High Clearance High Pinion D60s
• Unique 17 Degrees Pinion Angle Helps Reduce Drive Line Vibrations and Misalignment
• Peace & Mind Knowing that Your Worthy Investment Is Protected
• Lifetime Warranty – If you break it and you're still breathing, Rockcrusher will gladly replace it at No Charge
