AlphaVictorTango
Registered Member
Hi all,
Well I got my engine back together and it's been running great. Last week or so it started to tick a bit and sounded a bit off. Last night I pulled valve covers. Almost all of the rocker arms were loose. I readjusted the valves and it ran great! More power, no noise. On the drive home it stared knocking and running like crap. Got home and pulled valve cover again. Busted rocker arm. What gives? It also appeared that the rockers were loose again. It's a 350 TBi. I used 2 bolt heads on my 4 bolt block for a slight bump in CR. A mild roller cam and these obviously cheap asian rocker arms. Does anyone see a problem with replacing my broken roller tipped rocker arm for a stocker? Just for a couple weeks while I save for these? If so then I need to either modify my valve covers or replace with aftermarket right? Also does anyone have any insight as to why the rocker arm bolt may be backed off? Thanks to all in advance.
