Rocker arm studs
They need to be pulled out with a special tool. Most machine shops will replace them with a screw in style and that requires machining and tapping....
HTH
Mike
See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
I guess you´re changing the pressed in stock studs for screw in studs, right ? In that case you´ll need to mill down the stud boss the same amount as the nut of the screw-in one. Your local norwigan speedshop
hopefully has a kit for this operation wich should include a tapping guide. Why are you gonna do this, if I may ask ? The pressed-in ones are ok for a mild performance engine.
/Andreas
406cui of pure sh*t
<A target="_blank" HREF=http://hem.passagen.se/znus/>http://hem.passagen.se/znus/</A>
Just went through this myself, except for new heads. I'll start off by saying that if you are modifying the valve lift or are rebuilding a set of heads, have the studs pulled and screw ins installed instead.
I was told that as long as I keep the lift on my motor under .450, there is no reason to pull the factory studs. Again, these are brand new GM heads, and I am going to be running a roller cam with .429/.452 lift. Just a FYI, since I didn't want to spend themoney to have it done if I didn't have too.
Dorian
My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
