Thanks for the advise on the rocker boxes. I assume the outer rockers are welded on first then you weld/bolt rocker boxes, is that correct? I replaced the entire floor with a floor from Gmc Pauls. and now I'm trying to massage the outer rockers on. I have all the holes drilled in the outer rocker for spot welding. I assume you weld the outer rocker to the lip of the inner rocker "new floor."
after you weld/bolt in rocker boxes do you connect(weld) rocker box to inner rocker or not. this is probably confusing but there is not a lot out there on installing rocker boxes. I would be glad to send pics, once I figure out how to post the pics. Im located in Iowa City, Iowa
