Rocker panel replacement source
bigbadchev84
Hermiston, Oregon
Well I have been working on my door gaps a little more and tryed to re-situate the replacement rocker I installed, Well Now Its MESSED UP!!! The one I installed was a keyparts from LMC wasnt too Impressed with the fitment. Where is the best place to get one? I am wanting a good fitting one also, What have you had luck with? and where did you buy it? I am wanting to buy it tonight online so let me know guys, Thanks
From what I can tell, ALL the replacement rockers do not fit well. In several cases (mine included) the rocker sits about 1/2" too small at the front of the door. You kinda have to tweak it to space it away from the frame and tweak the doors and fender to match as close as possible.
The ONLY good fitting rockers are the G.M panels, yes they are still available as part numbers 3944882 and 3944881. They are kind of expensive but very much worth the cost if you want a nice finished Blazer.
Just the dealer, they are about $130.00 each. I can get them a little bit cheaper but by the time I shipped them to you it would be about the same cost.
