Rocker Stud torque specs??
what kind of cam? hydro or solid?
By the way I belive you are looking for valve lash not torque specs.
He wants the specs for the studs--screw in studs. You don't torque the rocker arm nuts, you have to adjust your valves correctly, it's not a torque spec.
Unfortunately I don't know the spec, but I figured I'd clarify your question for you in case someone knows what you're talking about.
