Weld on skid for your 2.5 ton rockwells. Ground clearance increase of nearly 2"!
3/8" thick steel and pure beef. Available both as a welded completed piece ready to be welded to your rockwell housing or unwelded for the "DIYer".
Either option includes the 3/8" NPT drain plug and weld in bung. If you choose the welded option, it will come to you fully welded inside and out.
Unwelded $85
Welded $125
Unwelded $85
Welded $125
