I just installed mine about three weeks ago (front and rear) /forums/images/graemlins/waytogo.gifI installed the rear just like it said in the destructions, then had to look at the front set up, after much head scratching and measuring, I decided to cut off 2 inches off each end of the down tubes, then set the feet in place on the floor of the truckstood the bars in place, then I took a small strip of wood about a 1/4 inch thick between the dash and the bar, ( I had to trim alittle off to get it to fit just right) and then spot weld on the feet, then up top at the other end, then cut down the spanner bar to fit and spot weld it in also. then weld like the wildman that you are, clean and paintthen drill and bolt. mine turned out "TATA'S and BEER" /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gifPS don't forget to use a level and a carpenters square.
place the feet in their designated place, as close to the outside wall as possible then follow above destructions.
