Roll Bar Padding Replacement Sugestions
Cheyenne75
Registered Member
Oregon
75 K5 the padding is missing in spots on the stock roll bar would like to find as close to OEM style thick replacement looks like it's one long piece with a splice seen some only in 3ft any in one full piece anywhere or what have you used that looks stock??? Many Thanks
I used pipe insulation from the Home Despot. The higher quality stuff is fairly soft, dense foam like the factory padding (as opposed to the cheaper plastic-y insulation.)
I seem to remember being able to get six or eight foot chunks, enough for your use. Then you get some 3M spray adhesive at the auto parts or craft/fabric store (bring your wife/girlfriend as cover) and you're done.
-- A
speed shop is where i got mine
