No slush box for me, don't have to wind it up to get going either and I take off in 1st (not low)
The advertised duration sounds high but the way the cam is ground it has long opening and closing ramps, they said it specs at 218/228 @ .050" but when I degreed it it came out to 228/232 @ .050" using a solid lifter with a 104 deg centerline.
At lower RPM's it seems like a much milder cam but when ya put yer foot in it it realy winds out, when I hit the freeway I stay in 2nd till around 4500 and then shift into 3rd.
Once I get rid of the 2" pipes and rams horn manifolds and get the 4.10 axles under it it should realy get up and go.
As it is it will bark the tires from a stop if I give it to much throttle.
