Roof Rack So Cal
It was on there when I bought it but there were 6 bolts through the roof holding it on. The rack has some pieces running across the bottom of it that have holes for the bolts and between the rack and the roof were some foam isolators so the metal wasn't in direct contact with the roof.
I've been thinking about this but not sure if I want to go with a roof rack. Plus, all I would have is a super low ball offer cause I'm broke, it's a drive, and still not sure if I want.
How come you don't just cut the sides off and weld it up clean? Or cut them shorter? Then at least you still have a rack you can strap stuff down on, and something to still use the holes that are in the shell.
do u have any way of weighing it or do u know how might have made it im very interested in it but need to figure out what the weight is of it.
I should be able to throw it on a household scale and get a decent idea of weight. I will do that tonight when I get home.
yeah, and if it comes apart in pieces, you could always wrap and ship it.
It's a Confer or Confur or whatever right?
It doesn't come apart from what I can tell, seems to all be welded together which is why I don't wanna ship. I can't find a brand name or anything on it either so I have no idea who made it.
AS LONG AS ITS UNDER 126 fedex will ship it any where they dont give a fling fart as long as it fits in the back of the fedex truck. as long as u have a comersal account. check ur pm's.
