Rotisserie
btblazer
Registered Member
Minnesota
I have a Rotisserie. Doing a restoration on a 1979 Blazer. Has anyone done this and what is the best way to hang the body on it.
The problem is that all of my mounts under the cab portion of the blazer are shot. I have to replace the cab mounts. Any other ideas out there. Thanks
On my sub I used 2)2 ton moter hoist ,cut the head off and razed it up about 8",boated to the fire wall about 8"down from top bend,drilled 3/8"holes grade 8 bolts ,with fender washers,I left them in for ground hook up post,,in the back it was cut off after the 2 seats,used 6"c-chanel,bolted to where the back of the seat hooks to,but the sub was cut off after that,,used 1" ratchet staps to hold it in place from rotation hope this help
