Hey guys I am working on my wife's truck 92 k2500 350/4l60
It started to ping a lot under part throttle, it also has a semi rough idle. Initially I thought the egr valve was bad and it was, I replaced it and the solenoid. I still have the pinging and rough idle. I checked the coolant temp sensor just to see if it was pulling fuel from a bad sensor, I unplugged the tps and o2 while running and no change.. I cleared the codes and drove around and still not getting the 32 like it had probably cause I don't have any level ground around here. I don't know what to do and I don't have much experience with tbi so not sure where to look from here.
