Sganderson
Registered Member
Hello all,
My 88 jimmy sounds as if it's missing or studdering whenever it idles cold. Seems to go away when engine is warm. It will also stall if if I don't hold the throttle down until it warms. It's never stalled other than after a cold start . There's also a smell of gasoline in the exhaust. I've adjusted the timing, replaced the O2 sensor, spark plugs and wires, distributor cap and rotor, and ignition coil to no success besides it running better overall. I've checked for vacuum leaks around the throttle body and body spacer with wd40 and found nothing. The only thing I can think of is a vacuum leak somewhere or a failing ignition control module. Anyone ever had this problem before? Thanks
