RPM Calculation
pomai
Oahu, Hawaii
RPM calculation
I’m terrible at math, could someone calculate RPM’s for me?:dunno:
About what should the RPM’s be at 50 mph in 4th gear?
700r4
4.56 gears
33” tires
Thank you very much,
Ed
Also have to add a few more RPM since tires RARELY measure on size and are usually smaller by almost an inch.
For an accurate tire diameter, you could always measure the actual "rollout" of the tire. Mark a spot on the tire, then move it forward 10 complete revolutions across the ground. Measure the total distance travelled, divide by 10 and that will give you a highly accurate circumference.
Convert circumference to diameter and plug it into the formula and you should be awfully close to a real life value.
:usaflag:
:usaflag:
Thank you,
Ed
