This is a chart we should all be familiar with. But back to the OP.
Now, of course the chart represents a 1:1 transmission ratio, but we're talking 700r4 per the OP. As you see the 'close to factory' ratio for a 35" tire is approx 4.56. In OD with the 700r4 and a .70 4th gear, you'll be happy with a few more RPMs, that's why 5.13s are great for the combo. Hunting trans is a mixture of things, more RPMs in a round about way tends to be one way of "fixing it", while simultaneously giving you low gear fun power. You can safely be on the 'more power' side of the lower gears with OD.
It's a heavy rig, with the aerodynamics of a brick, with big tires. It WANTS low gears.
The major factor is the tire diameter. Your muscle cars can be plenty happy with 3.73/4.10 because they still have regular sized tires. In a sense, you have to
overcompensate gear ratio due to the larger diameter tire. Nor do you need to be in 'better gas mileage' range, because that's handled by OD (once again, the chart represents a 1:1 tranny). It'd be a different story if you had a th350, 400 or sm465. Now add 65mph with a lifted brick with big tires, and you could really use those lower gears, especially when it comes to hills.
So you're not lowering gears to add power, you're lowering gears
to correct back to factory (if you choose)
