RPM's???
Re: RPM\'s???
4500 is the factory horsepower peak and I've never seen a truck that shifted below that.
/forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
You have to be kidding me tim /forums/images/graemlins/shame.gif...You are saying that trucks are not shifting anytime before 4500 from the factory....
I wouldnt want to ride in a truck that shifted that high..I'd end up with whiplash and be sueing GM. or deaf from the noise. /forums/images/graemlins/shame.gif
Apparently I missed this one.
I am talking about at WOT.
Obviously TV pressure, vacuum modulator, etc will come into play for part throttle shifts with an automatic.
Re: RPM\'s???
F1 & Indy car engines can't do much work (very low torque), but they can do it very fast (high RPM HP).
OTR diesels can do a huge amount of work (lots of torque), but they can't do it very fast (comparatively).
so would bullshit be too short an answer?
F1 and indy cars do a lot of work, GEARING. the torque is just at a higher crankshaft speed
comparing a motor with a flywheel that outwieghs an indy car to a race engine is not a valid comparison
put the diesel torque figure on a vehicle that wieghs the same and gear it to match the engine rpm and you get the same result IMO
x amount of pressure on the driveshaft = x amount of pressure on the driveshaft doesnt matter what is in front of the shaft in regards to gearing and rpm
I just helped send a vehicle to a 6.79 @ 210mph and only turned 4600 rpm peak (which is over revving it), did horsepower do that or torque?
as they are one and the same thing they both did it.
Torque is a measurement of the engine's ability to do work, i.e. how much work it can do.
HP is the rate that it can do the work at.
and how is horsepower measured? ah by measuring the TORQUE and hitting it with some math to add a time factor.
a motor cannot have any horsepower at zero torque.
Re: RPM\'s???
Yet an engine can have lots of torque and zero horsepower and net no useful work accomplished. (Electric motor at 0 RPM)
When comparing similar engines I believe horsepower to be a better comparison of the amount of work that can be done by the engine, but I also belive that the entire torque curve must be matched to the vehicle weight, stall speed, gearing, tires, etc., or it will be sluggish.
