RPO gear code.
Babaganoosh
1 ton status
Phoenix Arizona
I searched and found that there is only 2 "g" letter codes on the RPO sticker. Im looking this up for a friend and his says G80 : AXLE POSITRACTION, LIMITED SLIP and G50 76 88 SPRING,H.D. RR(VAR 1). If these are the only ones listed, is the raito not on the sticker?
These are the ones that I have found from another website
A01 76 88 WINDOW,DEEP TINTED GLS(ALL WDOS)
A52 76 88 SEAT ASM,FRT BENCH
C60 76 88 AIR CONDITIONER,MAN CONT
E63 76 88 BODY EQUIPMENT,FLEETSIDE PICKUP BOX
F59 76 88 STABILIZER,FRT
J50 76 88 BRAKE SYSTEM,VAC PWR
LE9 82 86 ENGINE, 305 C.I.D. V8 (305H)
NL2 76 87 TANK,AUX FUEL(VAR 2)
N41 76 88 STEERING,HYD(VARIABLE RATIO)
UA1 76 88 BATTERY,H.D.
V43 76 88 BUMPER,RR STEP(PAINTED)
x43 dont know
yfl dont know
zy5 dont know
Z49 76 88 MANDATORY CANADIAN BASE EQUIP MODIFICATIONS
17l dont know
77d dont know
A28 76 88 WINDOW,RR WDO SLDG GLS
cd4 dont know
D45 76 88 MIRROR,O/S BELOW EYELINE(STNLS STL)
F51 76 88 ABSORBER,H.D. SHOCK
F60 76 88 SPRING,H.D. FRT
G80 76 88 AXLE,RR LOCKING TYPE
K34 76 88 CONTROL,SPEED & CRUISE(INTEGRATED COMPUTER)
MX0 82 88 MERCHANDISING OPTION ONLY-DO NOT CATALOG
N33 76 88 COLUMN,STRG(TILT TYPE)
N67 76 88 WHEEL,RALLY TYPE(VAR 2)
UM6 76 88 HADIO,AM/FM STEREO CASSETTE ETR
xfl dont know
YE9 76 88 SILVERADO/SIERRA CLASSIC ( damn you asshole LMAOTRUCK)
zfl dont know
z31 dont know
Probably not. Not many axle ratios used in the later trucks, a sticker with no axle ratio RPO would lead me to believe that it's the "base" gears, whatever that was with that drivetrain combo.
