rgilmartin
Registered Member
running rough, very hesitant at the low end of the gears, but will accelerate and run better at higher rpm's..runs great for first minute after or so after starting..
a little cough at idle, recently started stalling when idling in D and it's hot out...
Did the 'tune-up thing, probably needed most of this anyway'... plugs, wires, cap and rotor. Changed fuel filter and O2 sensor.
sprayed carb cleaner around intake and tbi to check for vac leak, no difference.
cut off cat, was 'sure' it was clogged, it wasn't....
now what??
Thanks!!
-Ryan
now what??
Thanks!!
-Ryan
