Rubber Bushings and Motor Mounts
Jason Thompson
Registered Member
All right gentleman please let me know is there a kit that is sold to replace all rubber bushings? I need to replace a lot of the rubber bushings underneath hood, so do I just have to purchase each piece separate, or I was hoping there was some type of kit/package that sells all of them together.
I was also interested in your opinions on some good motor mounts. DIY4X has some "Competition" poly motor mounts that look good, has anyone tried these? My motor mounts keep coming loose and I believe they are probably original from *81. Please recommend, let me know the good and if you have experienced any bad and give pros and cons of each brand. I value you guys knowledge and appreciate the help!
JT
Diy4x motor mounts are excellent. You'll have to order a matching transmission mount from energy suspension. Diy4x can supply that for you as well.
What rubber bushings under the hood are you talking about?
Prothane makes the radiator isolators.
Energy has kits for the spring bushings. Many variables of I remember correctly.
i have run a few sets of energy suspension stock gm sell insert with no problems on the motor and there trans / t-case mount also no problems .
but if you want SUPER beefy diy4x or offroaddesign has them in a bolt in option over stock gm clamb shell .
