rubber fuel line.
77_Jimmy
Justin TX
the bigger line comming of the fuel filter housing is leaking on my truck. i think that goes to the ip. just found the leak yesterday just before dark. so does that hose go all the way to the ip , if so do i have to remove the intake?
Yes, it should be a direct shot from the output of the fuel filter to the IP.
It was a little tricky just due to the cramped space, but I've replaced mine without removing the intake.
