Found out some boob used about 15 feet of rubber fuel line hose instead of metal on my '85 Suburban with a 6.2..would that contribute to hard starting and it needing a lengthy cranking before it'll finally start??..the former owner installed an aftermarket electric fuel pump near the tank (on the outside of the frame rail,right in the path of salt spray off the tire,and the rubber hose was rubbing on the spring shackle and almost touching the exhaust pipe too!
..IDIOT!..
They by passed the original lift pump on the engine..I have both an elctric pump and the stock lift pump hooked up on my plow truck,and it works great,should I hook both up in this truck too??..once it finally starts it seems to run ok,the cold advance is working ok,it does seem a bit sluggish though,compared to my pickup's 6.2..
I know the engine has at least 2 dead glow plugs,but even on a 50 degree day I had to crank it for a long enough time to kill the batteries ,and then had to jump it off my other truck,and use a whiff of ether before it would finally fire up....truck has a Raycor filter on it and I see a bit of diesel oozing from the hose connection,so I'll have to fix that--but I dont think any air is in the system..
I was wondering if the long length of rubber has something to do with it or might be aggravation the problem..I'm going to replace it with 3/8" copper line instead,so I wont have to watch it rust away in a year or two anyway..good thing I looked under the truck,or it might have eventually burnt the rubber hose on the exhaust and I'd have burnt it to the ground!--not good,when its not insured or registered yet!..
..IDIOT!..
)..They by passed the original lift pump on the engine..I have both an elctric pump and the stock lift pump hooked up on my plow truck,and it works great,should I hook both up in this truck too??..once it finally starts it seems to run ok,the cold advance is working ok,it does seem a bit sluggish though,compared to my pickup's 6.2..
