Ruffstuff Axle Simple Swap Kit!
Gravel Maker
Sacramento, CA
This is the basic kit essential for an Axle swap, more items could be added but this is the bare minimum, You will receive 1 pair of our 3/8" thick A50 Steel U-Bolt plates with 3 pin mounting options, a pair of our Spring Perches with the same pin option to match, 4 - 10" x 5/8" Fine thread Grade 8 U-Bolts with 1/4" thick cut Hardened washers and real Ubolt Hardened Tallnuts, and a pair of Shock Brackets. This will get your Axle under the rig. BTW, this is NOT a Chinese made product that just can't hang with the big kids, this IS the Big Kid.
These go for $120 a kit before the Discount!
BTW, our Ubolts are the correct size for your Axle, not 1 size fits all.......these are offered with 8 Axle diameters and 5 Leaf Spring perch widths with 8 different Ubolt plates available. We have been making these for 8 years, somehow our thread here disappeared?
One of our most popular kits, we have about 50 variations available. If you don't see what you want call us and we can put it together!
