ShiftyK5
Need some feedback/info on ruffstuffs 14b axle swap kit. How many people have used it and did you need anything else for the swap. I wont be swapping to discs so i will be using just the simple swap kit.
as far as swapping in the 8 lug front axle all i should need there is new ubolts correct?
I noticed the 14b kit comes with spring perches, wont i be reusing my spring perches already on my 14b axle?
Last ??, Can you use the degree shims along with a zero rate?
