Ruffstuff's 3rd Weekly special!
Gravel Maker
Sacramento, CA
3rd Times a charm for some! This week not everyone will need these but if you do you need it bad;) This week all Panhard kits and Panhard parts are 20% off, these are real sales, not pretend sales that last forever so get on it before its gone Sunday the 28th!
Here is the description right from our website...
Setting up your Panhard / Track bar can be a nightmare if you don't have the right tools. We are the only company I am aware of that gives you options that make the Panhard / Trackbar easy.
All materials are 1/4" Plate and all are 4 sided so they have enough structural support. The general rule is for stock width on Inside Frame bracket & for full width on outside Frame bracket but remember, those are General rules so check your application and decide what will work best for you. For the axle mounting point space is nearly always at a premium so take your time and determine if you can use a Centered bracket or need the Offset bracket.
Its not rocket science and if you keep the Panhard & the Draglink as parralell & as close to equal length as possible you will not have a problem. If one is much shorter or at a dramatically different angle you will bind and it will not work well, eventually breaking either the brackets, heims, or bending the bar itself.
http://www.ruffstuffspecialties.com/catalog/panhardtrackbar.html
