Run it til it breaks
dstrbdxp-AK
Registered Member
alaska
A few weeks ago I started getting some very loud noise in the top end, well tonight I was able to figure out why.
You can see the issue from the pic. When I popped the valve cover off I found the rocker laying on it's side against the base of the head clean and out of the way. Tip of rocker stud broke off inside the posi-lock and the bottom end of posi-lock broke off.
Rocker looks fine other than a few scuff marks, pushrod looks good as well.
Any ideas as to why this happened? I ran through the top-end a few months ago and haven't had any issues since.
'69 396, 781 heads, all crane gear from the cam to the poly locks. I didnt build the motor. Studs appear to be factory, I'd say
I do a tad bit of hot rodding with it on the streets, keep the rpm's on the somewhat mild end :D
Same exact thing happened to me on the way back from BlazerBash 2002.... also in a 396 motor. Left me stranded in Barstow....what a lonely hell hole that place is.
It's not that easy to find a BBC rocker stud at a parts store, or junkyard either. I think we had to go to about 4 different places before we got one used from a salvage yard.
My solution was to replace all the factory rocker studs with quality ARP ones... that solved it for me.
:usaflag:
Ok well, maybe I have my foot it in more often than not, LOL. :whistle::whistle::D:D:D
I found another cracked polylock. I had only touched a few of the rockers not long ago, and from the looks of it those that broke had only 1/3 of the poly lock even engaged into the stud.
We've got some really good motor shops here, I can surely scrounge up a stud and I know they have a set of polylocks on the shelf.
I will say whomever built the motor put a lot of high dollar parts into the valvetrain.
I'd say using the posi-lock nuts, on stock length studs is a no-no. I don't think there is enough thread engagement on the nuts.
