airpix
Newbie
Shouldn't my 89 350 Sierra run with the battery disconnected if the alternator is good?
Airpix
Airpix
thats very confusing to me....
nope, electronics run off the battery, which is charged by the alternator. disconnect the battery, and you break the supply of electristy to the vehicle. only diesels can run with a dead/diconnected battery.
are you doing this to check the alternator?
voltmeter is your friend, bat alternator is about 12v, good alternator is around 14.4v
You can check the Voltage at the battery terminals. Then check it at the alternator with the positive lead on the output post and the negative lead on ground. Testing at both places will tell you if you have a voltage drop between the alt. and the battery.I've had this occur before on my mom's 97 Sub. I was told to disconnect battery to check alternator. Then my mechanic said NO! because of the electronics on the EFI. My question for further reference, is where to I connect the leads of the voltmeter to properly test? Thanks!
And for clarification, won't a carbed engine with points ignition will run indefinitely with the battery unhooked?
Yup older cars can be but the newer computer controlled cannot...How ever to get out of a tight spot you could hook up a jump box and leave it to get home.....I was wheeling with a friend that didn't have his battery secured and of course we busted it...used his jump box to start the truck and it died as he un-hooked it so we ended up just leaving it attached and driving home on it....I have ran older cars without a battery. Had a dead short in a battery once. pulled the battery out. Jumped the car and drove about 50 miles without the battery in the circut. Runs fine as long as you dont use any other power other than the ignition. Not a good idea tho. As said it can blow the diodes.
Would not do it on a newer computer controlled vehicle.
