dave_90_blazer
uh, guys, the breather is there to let air into the engine,, the tube to above the TBI is letting in filtered air(the tube is called the "PCV air make-up tube" in engineer speak), and too much vac in the crank case is bad, same with too much pressure, it with move gaskets(suck in or blow out) causing large oil leaks, 2 PCV valves are ok if you still have a breather to let air in (p.s., oil coming out the breather when the PCV valve/vac is good means you have too much blow-by, most likely caused by worn piston rings)
What fun! Thought we'd lost these!
