I am pretty stumped here. I have no running lamps. (I also lost the ipack lamps too but not 100% sure it is related.) I tried the easy thing and replaced the head lamp switch but no luck. looking at the wiring I can jumper the power to the fuse box at the grey wire(has no power coming from the fuse box and the 5amp fuse is good but has no power) when I jumper it the lamp warning sounder stays on and will not shut off with the key or anything so I am completely bypassing it. I also traced down the sounder and suspect there is an issue with the feed to the sounder box or something with the sounder box itself also there is no power at the orange wires @ the head lamp switch if.
HELP
I am about to just hard wire them to a switch but dont want to.
HELP
