- Joined
- Mar 12, 2004
- Posts
- 2,647
- Reaction score
- 1,043
5 minuets ok or just long enough to load it on trailer?
i'd like to, hopefully, clear up another possible myth that is also related to exhaust:
i noticed some heavy duty trucks and farm tractors have a metal flap on top of the exhaust pipe(s).
What is this for?
HA! Got there first, even if I had to post my shortest post ever!!
Myth.
You don't ruin engines from no exhaust. You ruin engines from running lean. There are still people who don't understand how that myth got started, now we know why problems may happen with no exhaust. This is that whole "you need some backpressure but too much is bad" pseudo-science belief.
Might it run lean with no exhaust? Likely, since Chevy exhaust is restrictive (stock) but if you have the induction setup for high flow exhaust already, your AFR is probably fine.
If you aren't putting a lot of load on the engine, it will be fine. I'm sure we can find all sorts of applications that use exhaust solely to direct the exhaust flow, and nothing more.
If it is a high performance high dollar engine, I wouldn't. But a stocker, yes.
), but I tend to agree with the rest of Zim's post.HA! Got there first, even if I had to post my shortest post ever!!
Your answer wasn't posted when I started typing!...but the first one that appears wins,right?...![]()
I have heard of the exhaust valves being liable to warping during the cooling process though--that's why the dragsters mechanics put tennis balls over the zoomies,so cold air wont get at the valves and cool them off too rapidly and let them warp...
