they suck.....
I've had 3 of those 250 "camel humper" sixes with the 2SE carbs--only one ran halfway decent--the other 2 had severe hesitation when accelerating and a "lumpy" feeling at part throttle,like it was surging--I rebilt both of them,new accelerator pumps,floats.etc--no improvement--the 2SE is just a complicated peice of junk in my opinion--
I ditched the one my 79 C10 had and made an adaptor to bolt a 4bbl edelbrock performer on it,and I disconnected the secondary barrels,so it ran only on the primary barrels--it ran 100 percent better and got better mileage to boot,but the motor lost the top of the #6 piston after 2 years(but I dont think the carb was to blame,I have seen several others sixes do the same thing--I think the lean mixture of the 2SE is whats to blame,and maybe blocking the EGR valve off didnt help)...
If your six has those pipes coming out of the valve cover and go to the exhaust manifold passages in the head,the "check valves" in them can leak and let soot and carbon into the air cleaner and carb--this screws up the fuel/air mixture and causes poor running--it also can let exhaust heat into the valve cover and burn the paint off,and carbonize the oil in the valve cover and the top of the head,where the rockers and valve springs are--this is another bad thing,it keeps everything from getting the correct flow of fresh oil to them,causing excessive wear...
I took all the pipes off mine and plugged the openings,but I dont have to get mine emission tested--your state might be different..It ran better with them plugged,but one hose that goes to the air cleaner is a breather and must not be plugged,or pressure will build up in the cranckcase..stuff a "bowtie" filter in it,like the one inside the air cleaner housing..I still didnt like the way mine performed,so I spent 2 days making a carb adapter and getting the throttle cable and detent cable to work again--..
Good luck with your 2SE carb,maybe the "check valves" will be the source of your problems,they make it look like its running rich due to all the soot from the exhaust going into the carb via the air cleaner...I liked the older 250's with a one barrel carb and a "Non Integreal" head--I think they were much better than the 2 barrel "camel humpers"---my 79 now has a 305 in it from an 86 van,and its like a whole new truck compared to the way it was with the 250 in it...
If your really stuck,I still have the 2SE carb,air cleaner and snorkel out in my shop--I kept it in case my carb adaption didnt pan out--and I have no use for it anymore,since the motor went to the scrapyard...
