Rust in cylinder walls of freshly bored motor, what to do?
y5mgisi
1 ton status
Portland Oregon
Theres not alot just a litle surface rust in some of the cylinders. I have some of that gell rust remover that i put on some other metel and seamed to do a good job of removing the rust and not the metel. I just dont know if it would be a good idea to use before the motor is broke in, seams like it might remove to much and give me blow by right there. What do you guys think i should do about it?:confused:
I had the same problem before, just soaked the cylinders in wd-40, wiped off the rust I could, then soaked the cylinders again, and rotated the engine by hand.
A hone would be yer best bet with a light rub would with some WD-40 as mentioned. I had to do that on a 351M that blew a head gasket.
its usually a monthly procedure for me on the boats... you can't imagine how many guys run old, bad exhaust (marine manifolds run water thru em, when they go bad, they leak right into the cylinders).
i've done many, no garauntee, in boat, hones with the bottom end together for my cheaper customers.. funny thing is, i've yet to have one fail compression tests down the road. :confused: :what: :doah: :smirk: pretty good for a hack procedure...
i usually use PB and a 3-arm hone...
if you decide to "deglaze", make sure you clean the cylinder walls very well. You dont want any rust or grit staying in the engine.
dont use "naval jelly"
Whatever you do,dont use "naval jelly" to remove the rust!--that stuff has phosphoric acid in it,and will "eat" pistons and bearings,if it gets in the cranckcase it will raise hell with the lifters and oil pump..I'd just lightly hone it and wash out any grit with hot soapy water and use "Motor Medic" or STP to coat the walls to prevent more rust...We resurected many "seized" motors at the junkyard I worked at for antique cars,that had sat several years,and I'd say 90% survived and ran good after we got them "unstuck" and got them running..:crazy:
use the wd-40 then coat the cylinders with a small amount of tranny fluid, this will keep it lubed and prevent more rust.
