Rust repair above winshield Help Los Angeles
scoots90245
1/16 ton status
El Segundo
I have some rust around windshield in my 89' Jimmy.
I can not find a shop near me El Segundo 90245 that does rust repair (cut weld) Can anyone recommend a body shop. I will not attempt this on my own. I will pay once and get it done right hopefully.
Yeah good luck.
That's a tricky area.
There will be no repop sheetmetal for this area. However, you can get that section from any 73-87/91 Squarebody in the junkyard you find.
Also, once you find rust up there, it is wise to look down inside the A pillar for rust and see what that looks like. You can access those areas by pulling the vents inside the cab.
Damn it hopefully it hasnt rusted all the way down
thank ill do a thorough check
