ljense8
Registered Member
So, I work a swing shift job, and this week it is my turn on 3rd shift(12am-8am). During this shift, things are pretty slow and my sleep deprived brain has lots of time to come up with crazy ideas.
The idea I have been toying with the last couple nights/mornings is building a custom body tub for my '91 K5 with diamond plate aluminum instead of using replacement panels from somewhere like Classic Industries. I would still like to keep the exterior panels factory, although they will need to be replaced/patched in the process as well. The two main ideas behind this being potential weight savings, and it would look cool. The thing I am wondering about is what gauge of aluminum would it take to provide sufficient structural rigidity? If I could use .125" or .063" sheet, that would save me some weight but if I have to go thicker, it wouldn't be worth it, in terms of both weight and money. Also, I have never welded aluminum, so I would have to find a welder in the area who could do this for me, but that shouldn't be too hard, since I know a few people who are pretty good. The alternative to welding that I sort of thought of and half dismissed at the same time would be to build a sort of frame for the tub out of angle aluminum and either rivet or bolt the diamond plate panels to that. This method seems like it may not be as structurally rigid and could provide ample opportunity for lots of squeaks.
Or, this whole thing may be a bad idea
. What do you guys think? Any feedback or ideas are welcome, even if you say it's the dumbest idea you have ever heard.
..especially if it sees any road salt...
we have to do it, and then go back in a year or two to find the elbows rotted clean off the aluminum.
