Junk yards are good but you do alot of searching. I have found a TON of K5's on Facebook Marketplace that are being sold for parts only. I am in the Philly area and there are at least 5 within 50 miles of me that are being parted out.Thanks for the suggestion, yeah I’ve got some work to do here. The other spots in the floor are fairly small, about 5 of them, this is the worst. Only known when I pulled it all apart. Not a hole in the roof that I can see, but will check closer. Guess I’ll have to find a junkyard to see if I can scalp this part.
I have a few of these dastardly little suckers forming on my truck, scary to see how much damage they can cause. I guess a cheap welder and some sheet metal working tools are being added to my harbor freight wishlistIf you have not found the cause of your rusted B-pillars, I may have. I spent the day salvaging parts from a K5. I cut out the B-pillars which had some exterior rust near the roof. Once the cab was removed we found major rust holes. Be sure you check the space between the roof and the back cab.
