This is why I moved to Tucson. I have a 1996 M1008 CUCV, product of Ohio. A few days ago I get in to go and immediately notice the brake pedal has way too much play. A little investigation shows that the drum side of the master cylinder is empty and there is a leak at the drivers side rear slave cylinder, right where the hard line enters.
I figure, I'll replace the slave cylinder and all will be well. This is a 14BFF, so out comes the axle, then some retaining stuff and a 50 pound rust ball of a gigantic drum. The bolts holding the slave cylinder in place are rusted to hell and immediately round out. Now my best idea is to pull off the whole backing plate so I can actually gain access the to bolt heads and maybe grind them off. To do this, I'll need to get the brake line off and of course it is corroded too and won't come loose... since the leak looks like it may well be from the line itself, now I figure I'll have to replace that line back to the splitter anyway, so I'll cut it to free the backing plate. Tracing it back, the line is pretty rusty at the splitter too, will I be able to get that free?
I'm going to have to end up replacing the entire brake system up to the master cylinder before this ever ends!
Moral of the story: pay the extra money for the non-rusted option. Fixing rusted vehicles is not fun at all.
..the spring plate under the u-bolts rotted away in the middle,only two strips remain where the u-bolt nuts bear against them!..(I got some used plates and u-bolts from a member here,still need to install them though)...my oil pan rotted thru 3 years ago,ever since then J-B Waterweld putty is all thats keeping the oil in it!..
