ymatt
Registered Member
Hey all. Greetings from the old country.
With the last few days exhibiting the first signs of decent, dry weather since last August, I decided to make the best of it and head out to resume work on the truck. What a difference some sunshine makes to the usual gloom... the air begins to smell good (except when being passed), and you begin to emerge from hibernation mode. Anyone in Arizona want to do a good deed and adopt me?
This post would probably be better off in the 73-91 K5 forum, but I don't seem to have the required permissions to post there anymore. Anyway, here's my problem:
I have a '78 K5 (extended front floor). The third frame crossmember from the rear is very rusty (the one underneath the front part of the rear floor that's in line with the spring eye and middle body mount). It's about 1/3 the original thickness in some places. I have already blasted part of it, but as I cannot completely remove the body from the frame, some parts of it are very difficult or impossible to get at, especially the areas behind the two side braces.
Apart from it being a VERY time consuming and awkward process to blast the crossmember, I'm not happy with the weaker, thinner metal that is left, particularly for a major structural section like this. I figure it would be much easier to grind the rivets out, and replace the crossmember with a new one. Has anyone already done this? If so, did you fabricate, or is someone out there selling a bolt-in replacement?
I would weld something together if that was the only option, but I want something that is at least as effective and strong as the original, and I have zero knowledge of chassis structures. Would anyone care to share their thoughts? I notice these frames flex a lot (don't ask me how I discovered that
), and in my book, that's not a good thing.
