jonathon
On a 4wd 2dr 1989 S-10 Blazer, how do the hubs work? Are they automatic or always engaged?
Thanks, that makes sense!Well, Mr Maggot is on the right track, just missing a couple details. There are no hubs per se. What it has is in the front diff, on the passenger side, what would be a long axle shaft in a solid axle is actually two pieces that spin independent of each other until a sleeve/collar slides over and locks the two shafts together. Once this occurs, the front axle is able to distribute power to the wheels. Both cv shafts/half shafts are spinning whenever the wheels are turning, but until this collar locks the shafts inside the passenger axle tube together, the passenger side axle shaft in the diff spins and the driver side axle shaft in the diff spins the spider gears in the differential unit without spinning the carrier/ring gear.
How does the collar know when to slide over and lock the shafts together??
When the transfer case shifter is moved from 2hi to 4hi or 4low a vacuum switch on the transfer case is activated sending a vacuum signal to a servo. This servo pulls a cable which is attached to a fork that slides the collar to lock or unlock the shafts. If any of the vacuum comonents are malfunctioning the transfer case will spin the front shaft, but no 4wd will occur because the shafts inside the diff housing will not be locked together. The ring gear will spin, but it will not transfer power to the wheels. What it will do is spin the snot out of the shaft that goes between the differential carrier and the passenger axle shaft (the one that the cv shaft bolts to). Think of it as an open differential in the rear of a truck. The left wheel is on pavement and the right wheel is in mud with no traction. The tire in the mud will spin forever even though the left wheel has traction. Same thing in the front diff on an S10 when the collar is not locking the two shafts together.
This exploded view may help picture what parts do what.
The cv shafts bolt to items #1 and #31. #18 is the sliding collar that locks #1 (with a couple extra parts on it) to #19.
Man, this seemed like an easy qustion until I started trying to put it into type.
Hope it helps.
Are they prone to failure or pretty reliable?
