S-10 diesel
bear76
here
I have an 87 S10 2wd that I'm going to start playing with. I wanted to know if anyone has any idea about a 4cly diesel that would fit in an S10?
Isuzu has a nice little 4 cly the 4JB1 that would be perfect. It's used mostly in industrial applications. It's very compact and no bigger than most other gas 4 cly engines.
89GMCSuburban said:
Do some research, S10's used to be option with something like a 1.9 Isuzu diesel in the 80's.
I don't think they were all that common even when new. One of my ex-girlfriends had one with like 400k miles on it (and that was the only one I've ever seen), it had been wrecked a couple of times by her brother and sister. Not to mention I live in the rust belt, so needless to say that truck was pretty damn ugly. But it was reliable!
Those little Isuzu diesel motors were outstanding !
If you are going to "wheel" this S-10 you are building than gear the hell out of it and think of the motor like a light switch - it's either on or off , not much variance in power at different RPM's but it will run for a mighty long time and outlast the truck when it falls apart.
Tom
cummins 4b or 4bt. bout the same size as the V6's found in an S-10. might need to upgrade to 4x4 front coils or even find some aftermarket lift coils.
they are found in bread trucks and normaly have an SM420 or 465 behind them. from there almost any 90* transmission will fit behind them. might have to find a flex plate and have some machine work done if you want an auto.
Toyota 4 cyl diesel from the mid 80's had a mechanical injector pump so NO ELECTRONICS... Very Simple.
And the Nissan Diesel from the same era is also a work horse of a motor.
You can probably find a whole Nissan or Toyota on Ebay for under $1K if you do some searching.
Post pics if you do it.
Good Luck
Early 80s luv pickups had an Isuzu Diesel in them. I had an 81 with a 5 speed and it would run all day long. It had 250K on it when my dad sold it and only had the oil changed and fuel filter changed. Top speed was about 65 on the floor in 4th. If you put it in 5th it would slow down:haha: . It also got about 25 MPG:D
Ira
Thanks for all the replies so far. I guess I should have told you why I want a diesel. I'm going to try making extra $ mowing lawns and such this summer (gotta feed my K5 addiction). I also have a 91 1500 2wd LB that also needs a new engine, maybe that would be easier to transplant? My goal is MPG and good torque.
Tried installing a 6.2 into an '85 2wd S-blazer that had a 2.8L V-6 once. Had a few clearance issues that I didn't fell like dealing with so dropped a SBC into it and sold it. Finding a factory Diesel S-10 would be cool and installing a small turbo on it should make it run acceptable.
Eye Soo Zoo...
We had a mid 80's Chevette "Scooter" for a delivery vehicle at one of the parts stores I worked at..it had the Isuzu diesel motor ..cant recall if it was automatic or a five speed,I only drove it about 3 times,as I was a counterman 99% of the time..it had 250K on it,and it was highly prized by my bosses father,he drove it all the time,even took it home and used it instead of his own car!..it got over 30 mpg,and I don't recall it ever having anything go wrong..might be the same motor the Isuzu trucks and S-10's used later on..
It got T boned at a bad intersection though...they still got 800 bucks for it after buying it back from the insurance company..a local cranberry grower bought it for the motor,to use on a bog pump!..many VW diesels are pumping water in and out of cranberry bogs here too..one guy I know has an old scout with a six cylinder Nissan diesel pumping his bog water..
Though a 4.3 Olds diesel would bolt into an S10,I don't think its a worthwhile effort..those motors are the little brother of the ill fated Olds 350 Diesel..by like transplanting a time bomb into it!..I's go for the Isuzu or a 4BT Cummins from a bread truck..
I saw one getting sold from a Grumman "P" series with a TH400 attached for 1000 bucks a month ago,at a local junkyard..the guy who bought it scrapped
the aluminum body,got 500 bucks for it!..then hauled the rolling chassis,complete with brand new springs,michelin 19.5" tires,and a dually rear to Maine,where he plans to swap it into a GM crewcab.
It would be a lot easier to just buy an ols Nissan or Toyota or Isuzu diesel truck in your case though..good luck finding a cheap diesel now,the prices skyrocketed since gas prices went up around here...:crazy:
.:crazy:
jeep cherokees had a diesel option in the 80's. My old AMC cherokee had the chevy 2.8 v- in it. The diesel should have a similar mount setup.
Bigg R said:
S10's and blazers in South America came factory with a 2.8l diesel in them! Locate one of those!!!!!
Bigg R
Yup, South Americans could get the Isuzu diesel in them. I understand it was quite popular. Maybe look and see if you can find a repair manual for the South American versions and you'd be able to find out all the parts needed.
