G-Force8
I'm swapping the axles from a '76 k20 (D44HD/14BFF) in place of the 10-bolts under my '91 Suburban and I'm lifting it at the same time. The D44 is out of my reach in a storage unit at the moment. I'm putting in an order through ORD for the extended S.S. lines and I'm not sure if the front lines are 10mm or 7/16th's.
I've heard that 79-91 solid axle GM's (10-bolts) fronts use the 10mm and that the '73-78 D44/10-bolts use the 9/16ths primarily with some 10mm mixed in.
anyone know for certain?
