MT wheeler
So I am at another spot in the never ending build/drive dilema. A little background info. 1980 GMC Jimmy, 52" front spring swap, B-52's and new shackle hanger (DIY4x), new 2wd drive box with 1/4 wall DOM crossover and all 1 ton TRE's. FRONT: Dana 60 front with 4.56 gears, dually hubs, H1 12bolts with rock rings and PVC inserts on H1 takeoff tires. REAR: 14 bolt, shackle flip (DIY4x), 4.56 gears, 3.5" steel wheel spacers, Same H1's as the front. Both axles rebuilt with all new parts. Front and rear leaf springs have all new poly bushings.
The shackle flip is where the current issue started. When you do the shackle flip it moves the axle forward. To handle this I installed new heavy duty spring perches with offset holes to move the axle back 1" or 1.5" I dont remember which. This did not solve the issue. In doing reading about different springs I bought a set if Tahoe springs to move it back another inch with the longer spring and greater distance to the center pin. Initially I thought this would be enough but now I'm not so sure. Looking again at spring specs I see that some S10 springs are also 54" long like the Tahoe springs but an offset of 28" and 26" on the center pin which would set the axle back 2" which would seem like enough. BUT they are S10 springs not fullsize. From what I have seen it appears the spring rate is the same from the S10 to the Tahoe at1750lbs. If this truly is the case the S10 springs would/should work great. This is a daily driver that tows my camper and carries my family. I want it done right.
In searches for this I keep getting S10 trucks on full size axles and springs and the such. Any help whether the S10 springs are good on a fullsize would be greatly appreciated.
