Dabba
i notice govliquidation never has the keys if the truck may run or not
Corey - S10's suck.. go full size. S10's are cramped, the mileage isn't much better than a full size, they're harder to work on 'cause you've got less room to swing wrenches, and half the damn thing is metric,thus every job that would be simple on a full size takes twice as long to accomplish.
Buulllllshh***t
Only standard stuff on my blazer are the lug nuts and sparkplugs![]()
Yours is a 96 right?
mine was an 87..it had a mix of sae & metric on it..if yours is free of indiscriminate assembly practices, good for you. My experience was otherwise.
The keys are universal on the CUCVs. I have two and either key will fit in either truck. If you can find one, just have it copied. FWIW both mine came with keys. It wasn't an issue.
The only capable S10s I've seen are ones where the S10 body is on a K5 or other full size frame and running gear. And they're not nearly as cool!
, but your prolly needin a driver now and doin the sas or bodyswap to fullsize frame would take a little while and like i said your prolly needin to ride in it now!
