Stomis
Professional Amateur
Has anyone done it? I wanna move my saddle tank between my frame rails and just extend the gas lines and wiring to save some money. Whats the best way to mount it?
I have not done it,but i'm subscribing to hear what others have to say.I have an aftermarket 25 gal saddle tank on my 80 K20 and was just going to relocate it to the front of the bed with some protection so I could still use the bed without worry.I would guess if the lift is tall enough and maybe a body lift for extra clearance.I would want it at or above the bottom of the frame,but anything would be better than where GM put them.
Yeah.I just wen't down to the garage to look.If your suspension lift was large enough and the flatbed setting a ways up off the frame you just might be able to fit 2 between the crossmember for the rear spring and the spare tire crossmember.Bumpstops would keep the axle out of them.Point Pleasant-That's pretty close to Lakewood?Used to spend a lot of time down in Seaside.I have an uncle in Brielle and I think my cousin moved to Point Pleasant.I miss the beach.
Not into trucks.I haven't seen her since my Grandma's funeral like 10 years ago in Lakewood.
What about using the straps thru a hole in the framerail so they can be tightened just like the factory only in reverse?
Pics when the deed is done![]()
I already thought about doing this and the frames on our GM trucks are too narrow, the tanks will hit the driveshaft.
On my jeep wagoneer, it will be a tight fit but it will clear the driveshaft.
There are a couple problems that I ran into while checking it out. I had pulled one tank to have it cleaned so I tried it then and found it will hit in a few places. It hits the drive-shaft, the tail-shaft on the t-case, and in order to clear the t-case the tank ends up extremely close the the rear axle arch of travel. Fabbing the new brackets or making use of the oem ones is actually easy because you can you them in the same manner that the factory did, just on the inside. The tank itself just doesn't fit.
Also keep in mind the filler neck for the tank. You have a flat bed so it would be a little nore straight forward to route.
