Saddle Tank Filler Neck
ProJunkRacing
FrankFort IL
I got an 86 Shortbox and I have saddle Tanks, I was just wondering where I could get A filler neck and whatnot for the tank , also I run Carb , and there are 3 outlets on the sender, I used the biggest for my feed line what are the other 2 what should I do with them?
Any Ideas , help Just trying to wrap this project up
No return line is needed, if you are running just a carb.
you can get a fender filler kit for your sadle tank from any distibutor that sells Jaz fuel products, I got mine from them.
good luck.
My '86 C10 is OEM from factory with carb. It has a return line. Whether it's needed or not, I don't know, the factory thought it was. Mabey it's not though.
Look at your fuel pump, it will tell you if you do. Was the truck originally carbed, or was efi converted to carb. My truck has a mech. fuel pump with three outlets, 1 from tank(s), 1 to carb, and 1 retrun to tank(s). If you only have 2 outlets on your fuel pump, then you won't need the return line.
If you have a elec. fuel pump, I can't help you, I've never dealt with all that new stuff!
originally carbed when i got it, i believe he's still running the carb. there were 3 ports on the stock fuel pump. its in my 73 now.
yeah elec fual pump inline so therefor i will run no return i guess ,but do i cap the outlet and just use a vent or what
