odoa3
My K5 has a six inch all spring BDS lift on it with less than 100 miles on it. The rear looks like it sets between one to two inches lower than the front. I have a big plastic tub in the far rear for parts, fluids, supplies, recovery gear, etc. I also just added a pretty solid 2x4 rear bumper and will be adding a swing down tire carrier that will hold a 35x14.5 Bogger on a steel wheel. So, quite a bit of weight will be situated in the rear.
What is going to be the best way to take care of this sag? I was thinking about a 2 1/2 shackle flip, but was concerned that it would be too much. I thought I read on here some where that you get more than 2 1/2 inches of lift with them. I really prefer more of a level look. Anyone have experience with shackle flips that can confirm or deny the actual lift numbers? Any other ideas to solve this problem?
If you are looking for a set of zero rates, contact Greg (Intense Off road) down on the pennisula... he can get them to us cheaper than buying them from ORD.
