I'm looking at purchasing a super charger from TorqStorm. There kit comes with an aluminum Saginwa GM Type II/TC power steering pump and 10 AN feed.
I have PSC’s Steering Assist, Steering Gear Box, Saginwa P Pump with Remote Reservoir & I also have Hydroboost.
I wanted to keep all my steering gear PSC.
I also wanted to keep my 12 AN feed and the PSC Saginwa GM Type II/TC power steering pump in Steel.
PSC Hi-Flow Type II/TC pump, 1500 PSI & 2.8 GPM (Steel)
TorqStorm’s pump1500 PSI & 3-3.5 GPM (Aluminum) and come with 10 AN feed.
TorqStorm position is the PSC pump won’t fit there brackets.
PSC:
A side note, vendors of hydroboost units state that hydroboost units do not respond well to being overwhelmed with too much fluid volume, so keep that in mind when building the project.
Lee Power Steering:
These Type 2 steering pumps can be found in both Steel and Aluminum versions. Our years of experience have shown us that the Steel version has a much longer life span and will handle higher temperatures, therefore that’s what we sell.
My questions are:
What’s your opinions on steel vs aluminum Type II pumps?
Will It be ok with the 10 AN feed? Or should I change the fitting to 12 AN to match what I have know?
GPM? Would the TorqStorm’s pump with 3-3.5 GPM be a potential problem for my hydroboost?
Am I making to much out of nothing and should just go with the TorqStorm’s Pump, so everything goes together correctly?
P
ictures are just to share.
PSC:
Lee Power Steering:
My questions are:
P
