SAS for H2
patnick
Registered Member
vegas
Does anyone know of SAS for an H2 ?
A friend on mine does offroad tours with H2s and is constantly having problems with the front IFS suspension. Everything from balljoints to axle housing and suspesion bushings.
A quick call to ORD and I was told due to the frame being wider a standard truck kit will not work.
Any and all comments are welcome.
I just did a sas on my 03 2500hd with a bloody knuckle garage radius arm/coil spring kit. You could talk to jim there and he could make a set or radius arms that would fit the frame so you could use a 60. Look them up on facebook.....im almost sure he would help you out. Prob then use dual shocks with shock hoops.
If ya have the knowledge to cut the IFS out and install a kit then why not do leafs or radius arms yourself? Theres no math to it, its basic fab that you can get the brackets from ballistic fab and some handy work with some good angle and you could make the stuff bolt on.
