SAS stuff/HP leaf sprung housing/flattops
1-tonmudder
In a junkyard somewhere
78 F-250 HP bare leaf sprung housing $150
Flattops $100
Parts are located in Greeneville and prices are plus shipping.
I knoticed those flat tops only have a 5 bolt pattern... so they will only work with Ford outers I'm guessing. Chevy used a 6 bolt pattern on the spindles.
Yes you are correct,and they will not work with 1/2 ton brakes.The Ford flattops that accept the 1/2 ton brake's were only used on the F-150 super cabs.The 1/2 ton pickups(non super cab)and bronco's are different.As usual Ford had to complicate things.
