93Blazed
Registered Member
- Joined
- Nov 23, 2012
- Posts
- 8
- Reaction score
- 0
Hey guys,
New here but looking into doing an SAS to my 93' Blazer. I'm wondering if anyone has ever or has a check list of sorts that lists out all of what is needed and what needs to be done. I was able to pick up a 78' Dana 44 for $90.00 here locally. It's gonna need a go through for sure. As for the Blazer I'm planing on 3" lift total with the ORD kit and stock 47'' springs up front. Either a 3" block or new springs in the rear. I don't need to go crazy high just want a bit more tire clearance and with 160K on the chassis the IFS is getting loose. Rear end is 3.73 right now and I'm comfortable with the way it drives and tow's. I've got plenty of power under the hood.
Thanks for any links or help with this guys, just want to get everything on hand and ready to go before I tackle this job.
93Blazed
The balanced/Blue Printed built 350, 204/214 cam, Roller rockers, TBI Spacer, Flow Matched Injectors, Full MSD Ignition System, Salad Bowl, TBIChips.com Custom chip, Hooker Headers, Flowmaster Muffs, 32" aluminum radiator, 100 Amp alternator, high torque starter.
On the Salt Flats in Bonneville this past Summer.
93Blazed
